Chasing a rough idle?
2009TahoeLT
I've used the test before on older trucks at work to test of something is bad. usually you can unplug it, it default to a set value and judging by if it runs better or worse. it can help you what a direction to go in. but since I've not actually tried it on my own gm truck, is it possible it can look at the rear o2's if the front are disconnected? new one in me.
either way, my thinking is your ecm is removing 8% long term and 8% short term. that's enough fuel removed its going to run bad from being lean even if everything else is correct. so need to find out why it's doing that.
did you notice if it ran any better while the trims were at 0 while warning up?
It was still running a little rough but was a little better but it was also idling at 675-715rpms at that time. Once it settled down to the 575-615rpm area it started sputtering again worse. I checked misfires again and at idle there’s no misfires even with it running rough. But once you hit about 1100-1600 it misfires on almost every cylinder but 1 I believe
I read that you did the crank sensor relearn, but do you know if that's an OE sensor? Or if it's ever been replaced?
2009TahoeLT
Honestly no idea. It could have been replaced or could be oe. I have no records on it sadly
I would still a do a backpressure test if a cat is clogged it will cause the misfires that are otherwise unexplained
2.5 psi is max allowable, mine had 5 psi at idle and 10 with throttle. drove normal around a city street but no power, gutless wonder
not sure if it helps but
mine didn't show up until higher rpm's (under a load) but it translated into knock retard, skip to about 1:40
I could barely get it to go over 80-85
2009TahoeLT
I’d have to go buy a gauge to test it. I can try and get one tomorrow
you should be able to find something at harbor freight or make one out of stuff found there.
just needs to fit in the pre-cat 02 sensor bung
it could be something else but probably a good idea to rule it in/out as part of the troubleshooting process
2009TahoeLT
Also I noticed earlier when revving it to the 1100-1600rpm range to check misfires. I was getting some popping sounds from the exhaust, backfiring.
2009TahoeLT
Found this online I can pickup tomorrow. Looks like it has the o2 adapter. If this won’t work I’ll have to order off Amazon
2009TahoeLT
O2 sensor is stuck on there pretty good. And it’s getting ALOT colder here. Might have to wait till a decent day to do it.
CaliCrusin
