Lower center console side removal
Stbentoak
In the Denali there are padded leather sides on either sides of the center console by the passenger and driver seats, do these pop off easily? I have a rattle I believe coming from this area that I’d like to look inside there if they can be removed and replaced fairly easily.
I do have these stiff plastic interior pry bars if they would help.
mpthompson84
Did you end up figuring this out? I want to remove that same trim piece but the one in our Denali is different than what’s in the video (ours is one piece vs two separate pieces).
My issue is that the driver side piece sits tight and flush to the center console but the passenger one is not fitting tight and there is a gap I can see down into since I see it at an angle. Hoping I can just pop it off and see if anything broke or if I can adjust a clip to make it fit tighter against the center console.
Stbentoak
Stbentoak
No, I'm out of warranty and while irritating, not willing to screw something else up further that will cost me more down the road....
Lewii
