Stuck in 4 wheel low
dps01
N. TEXAS
Just to rule it out, you could check and clean the two ground points that are on the body mount on the frame under the driver's door hinge. One has two wires and the other has one. Don't just eyeball them, remove and clean them.
Concur… easy enough to get at…. Definitely worth cleaning (all contact surfaces) and reassembling…
tahoecowboy
A few other things you can try, drive forward and back a couple feet and turn the wheel back and forth to release pressure on the drive line if it is bound up. Wiggle the shifter to make sure neutral switch is fully engaged, and it has to be in neutral not park. Try putting it in other modes like if you are just trying to put it in 2hi, try 4 hi. Look at the actuator power wires make sure they are not broke, and check the back of your switch to make sure it is fully connected, not sure if 2006 is buttons or switch.
waveryd
IL
Transfer case encoder ring will likely be the fix unless there are wiring issues. .
It may or may not have codes with these symptoms. I would only use OEM GM parts for this type of repair.
Black02HOE
