Range Technologies for 2021 Yukon
Marky Dissod
So, to be precise:
It disables 7-cylinder mode, 6-cylinder mode, 5-cylinder mode, 4 cylinder mode, 3-cylinder mode, & 2-cylinder mode,
but it does NOT disable 0-cylinder mode?
Antonm
So, to be precise:
Which would happen literally every time the vehicle comes to a stop correct?
Or I suppose also anytime you want to slow down (like going from a 55 mph speed limit zone into a 45 mph speed limit zone), which would be a lot during normal driving.
PPV_2018
Senior Member
U.S.A.
@Antonm just my opinion but I feel like you should make a dedicated thread outlining your observations about the range unit.. DFM/AFM ‘disable’ is of interest to many of us here, and it would be good to have the discussion about the truths (and falsehoods) about what the Range units ACTUALLY do and DON’T do in one place…
Antonm
Be a short thread that'd go something like this,, The Range Tech DFM disabler,,, it DOES NOT actually disable DFM,,, the end.
Marky Dissod
So, whenever Throttle Position Sensor = 0%, 0-cylinder mode is likely?
(Fix your sig, then.)
Antonm
Fixed (thanks, I'd forgotten about it).
Since you beta tested the device, I'm guessing you know people at the company. Please ask them if/ when they ever intend to make an actual DFM disabler (you know, one that just turns DFM off) and I'll be the first in line to buy one.
Scarey
Have any of you tried Carbyte? I’m curious what your thoughts are?
jerry455
Due to these vehicles using Global B architecture, nobody might be able to actually stop the DFM mode, just "trick "it into not going into it. There are no companies making tunes yet due to the complexity of the programs and security. Stopping it from enabling might be all that these devices can do, especially at the price points they are at.
KMeloney
A couple people here have the Carbyte. I think I'll start a comparison thread and let the users of each explain the pros and cons of each.
readymanus
I'm running the Carbyte in a 2025 RST 5.3L. It's nice to have 8cyl on tap 'all the time', especially after coming off a 6.2L LTZ.
And of course the auto stop/start is gone.
wach3130
