iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 835
- Reaction score
- 446
Unplug it and clean the connector? Can you use crc electric parts cleaner? I know that stuff can make some plastic brittle. Don’t ask me how I know
It's all I run! Of course she'll run better on 93!Was thinking about running 93 octane… is this really necessary? And than add some chevron with techron? Heard good things. Someone said IAC so maybe it is idle related. Idk
On my scanner my truck was already warmed up when I did the load test at 2k rpm on the alternator. I did it twice and it said bad and than said warning on the second go.It's all I run! Of course she'll run better on 93!
As part of RVC, when the truck first starts, for the first minute or two or however long the computers decide, the alternator runs at full output before switching to another charging schedule. That's what that tester was seeing. Now, if she's always running at full output, the alternator is trying to keep alive a bad battery.
I wanted to start to figure it out, but now it's stone cold dead. I have dual batteries that are maybe 4 years old, and a mechman alternator. I drove it Friday and it was fine, but yesterday it's dead enough that the interior lights don't come on.Maybe we can knock this out together
Make sure the RVC is plugged into the current sensor on the negative cable right off the battery. If unplugged, the alternator will run at maximum output all the time.On my scanner my truck was already warmed up when I did the load test at 2k rpm on the alternator. I did it twice and it said bad and than said warning on the second go.
You think mine could be running at full output all the time? That would explain the over charging guess I don’t know. At the same time even though my truck was warm. I did have to restart it to do the test so I’m not sure if it has to go through deciding how much power it gets each time you start it or what
What’s an rvc and what does it doMake sure the RVC is plugged into the current sensor on the negative cable right off the battery. If unplugged, the alternator will run at maximum output all the time.
Would you be able to drop a photo for referenceMake sure the RVC is plugged into the current sensor on the negative cable right off the battery. If unplugged, the alternator will run at maximum output all the time.
Ok the plug in that’s fixed to the condenser ??Here
Growing up doesn't have to suck
Instead of a long typed response, here is the jest of it: "The bypass valve – otherwise known as a pressure relief valve – is an integral part of the oil filter. The valve is designed to open when the oil filter becomes clogged or when the oil is too thick. This allows the oil to bypass the...www.tahoeyukonforum.com
