Need some advice on which direction to go
iboughtatahoe23
iboughtatahoe23
Was thinking about running 93 octane… is this really necessary? And than add some chevron with techron? Heard good things. Someone said IAC so maybe it is idle related. Idk
It's all I run! Of course she'll run better on 93!
As part of RVC, when the truck first starts, for the first minute or two or however long the computers decide, the alternator runs at full output before switching to another charging schedule. That's what that tester was seeing. Now, if she's always running at full output, the alternator is trying to keep alive a bad battery.
iboughtatahoe23
iboughtatahoe23
On my scanner my truck was already warmed up when I did the load test at 2k rpm on the alternator. I did it twice and it said bad and than said warning on the second go.
You think mine could be running at full output all the time? That would explain the over charging guess I don’t know. At the same time even though my truck was warm. I did have to restart it to do the test so I’m not sure if it has to go through deciding how much power it gets each time you start it or what
Make sure the RVC is plugged into the current sensor on the negative cable right off the battery. If unplugged, the alternator will run at maximum output all the time.
iboughtatahoe23
iboughtatahoe23
Would you be able to drop a photo for reference
89Suburban
Bull in the china shop
SE PA
Here
iboughtatahoe23
iboughtatahoe23
Here
Ok the plug in that’s fixed to the condenser ??
Jongrreat
