daytime running lights sensor?
igell
so recently my 2001 denali no longer activates the daytime running lights. The truck basically turns on the headlights and mutes the dash lights the whole day.
Where can i start troubleshooting this?
where is the sensor located?
J Mac
Newport News, VA
My 04 was the same way...night mode all the time. Not sure if 01 is the same but on mine the sensor is a little brown plastic bubble on the center of the dash at the base of the windshield. Previous owner used to leave stuff on top his dash and something slid across dash and broke sensor. What a PITA to replace! Best way I found was removing radio and going that way. Had to get one of my teenage daughters to get sensor into hole and twist locked. No way my hand would make it back there.
I
igell
so i have two bubbles on my dash.. do i need to replace both?
JonnyTahoe
Minneapolis
Press the Dome Override button 4 times your lights should go off.
SMJT
I have the same problem with my 2001 Tahoe. The daytime running lights never come on and I have to press the dome override 4x to get the headlights to turn off. But I want to fix the problem, not just get the headlights to turn off. Did you ever identify the cause of this problem on your vehicle?
Scott in AZ
Arizona
This is the same problem as I have on my 2001. It is almost certainly caused by the electronic failure of the ambient light sensor on the center of the dash, under the windshield and the rear view mirror. THere are two types of sensores that look the same, but have different pin configurations. Amazon carries both.
I've removed my radio and looked around - am nearly certain I cannot reach in thru the radio box. My plan is to remove the dash (...and probably paint it with colormatch while it's off) and remove the sensor, then order the one I need.
Good luck! Let us know what you find out.
strutaeng
Dallas, Texas
I replaced it on my 99 Silverado NBS. I think I used some needle nose pliers to get back there?
On my 06 Suburban the little hole where that sensor goes is empty. Not sure if it fell down (probably?) I should take time to take care of that...
iaminfiji
