Air ride Edgy Mods question
CCPLuvr
Today our new AT4 is going in for wheels, tires and Edgy Mods links installed. I've got a question regarding increased ride heights for those that have done this. Will we see an increase of up to 2.5" in the lowered and normal ride height positions? I'm assuming we should measure the vehicle prior to and after installation in the park position, and that should be the same difference we'll see in Normal ride height? Any insight will be helpful. Thanks.
KMeloney
Did you already get your answer since installing the links?
C
CCPLuvr
Yes, but not till after they were installed. I've got to remove them and readjust, they're too low right now.
John from Edgy Mods said to disable the entry position so the suspension is always at Normal ride height prior to installation.
Once I get it corrected I'll post some pics.
Thanks for asking!
PMB 73
Thanks for asking!
Have you installed the Edgy Mod links? What size tire did you go with? Also, how do you like the ride after with the EM links added?
C
CCPLuvr
I didn't keep the overall adjusted link lengths used on my AT4. The ride is a little firmer than stock but it's still smooth driving it.
C
CCPLuvr
Here's a couple links after this was finished:
C
CCPLuvr
The alignment was WAY out after adjusting the ride height. Getting it properly aligned helped the ride as well.
PMB 73
Perfect, thank you for replying. Looks great! I would have to say my biggest concern is how it drives afterwards. Smooth is good! Have you taken it off road or tried to test the air bags?
rip mattock
