I’ve owned my 2007 Tahoe (VIN 1GNFK13087R398559) since new and I’m finally getting around to some quality of life upgrades. One of the things I’m working on now is getting Bluetooth to function with the existing factory radio. I have already purchased and installed a Crux BTS-GM1X module for Bluetooth music but I would like to add Bluetooth support for phone calls as well.
I read through this forum and found that the Onstar Module (VCIM) contains the Bluetooth functionality for Phone calls, and that it was an easy swap. I purchased an Onstar Module from a 2012 Tahoe (P/N 22832743) from eBay and made the swap today.
The module I received from eBay has a single coaxial plug and three sockets labelled J1, J2, and J3. Its P/N is 22832743.
![IMG_4285.jpeg IMG_4285.jpeg](https://www.tahoeyukonforum.com/data/attachments/440/440256-f6157f18da94d88e6c0c4e8eacd225f8.jpg)
The module I removed from my 2007 Tahoe has two coaxial plugs and four sockets labelled J1, J2, J3, and J4. Socket J4 did not have anything plugged into it. This module’s P/N is 25826499.
![IMG_4286.jpeg IMG_4286.jpeg](https://www.tahoeyukonforum.com/data/attachments/440/440257-a63f2d2a269cd0e5e66b51ada2f0b584.jpg)
Despite the differences, I swapped the module anyway. The vehicle turned on as usual and I received no error codes, but I was unable to pair anything to the Bluetooth. Here are my current theories:
1. I am not doing the correct Bluetooth Pairing procedure. I am holding the “talk” button on the wheel but the system does not recognize any pairing commands
2. I have the incorrect module and it is not compatible with my vehicle, a new module is required. What part number do I need?
3. My vehicle’s Navigation System is incompatible with Bluetooth Pairing and I will need a new Navigation Unit.
4. My vehicle is simply incompatible with Bluetooth calling and I will have to settle for a third-party integration or nothing at all.
I’m really stuck here and would greatly appreciate any help. I want to keep my vehicle as close to stock appearance and possible and don’t want to change to an aftermarket Navigation unit.
Thanks,
Thanks,
