donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,666
- Reaction score
- 2,950
That's a gen 3, not the issue us gen4 owners have.Judging from your old valve cover, you have a lot of engine blow by either past the rings or valve seals. Or simply a plugged PCV hose. Should look sort of golden inside. Below picture is an LS 6.0 at 120,000 miles, oil changes every 4,000 miles.
Had another set of heads on the shelf ready to go, and since I was pulling these off to change minor head gasket leak.... Put the other set of heads on with updated valve covers
gm shafted us 2007 to 2011 gen4 owners by selling us vehicles with a defective pcv system, see this TSB: https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
