No 'ACC' equivalent in ignition?
homesick
My truck, '07 Escalade, has no 'acc' position for the key. I assume this is by design, and not a defect; but I'm checking with y'all, to be sure.
There used to be an 'acc' selection, immediately CCW of the 'off' position on GM cars and trucks. It was perfect for listening to the stereo while waiting for someone. Now, the stereo shuts itself off after a while [10 minutes?].
I like the old way better. Any ideas?
joe
joe
You just turn the key one Click forward
homesick
homesick
By 'forward', do you mean 'clock-wise'? That was/is 'on', which powered-up all normal systems, before and after the engine was started.
Are you saying 'acc' is now included in 'on'?
I remember that part of the reason for using 'acc' instead of 'on' was to prevent burning the points; but the 'acc' position was still there long after points were history.
joe
mikez71
Totally forgot about that old reverse ACC position!
I just checked my '12 to make sure..
But like Doub said, it's one forward click for ACC, before the RUN position where your dash lights up.
joe
yes clockwise, one click, you should see the shift indicator light up and radio turn on, no other dash lights until the 2nd click which is "run", next click is start.
homesick
homesick
I just checked my '13 to make sure..
I went out today and explored more carefully.
I had never noticed the position you're talking about, as a distinct position. I think I subconsciously assumed it was just a bit of slop in the ignition switch as I switched the key from 'off/lock' to 'on'.
joe
homesick
homesick
How long have you owned this? Problem just started or been this way all along?
---edited---
I've had it about 2 1/2 years. It's always been, but, thanks to y'all, I think part of the mystery's solved.
The reason for this thread was that this new and improved 'acc' times out after some time [10-15 minutes?] and shuts the stereo off. I was hoping for a solution to that.
joe
radmann07
