Help Diagnosing Oil leak
rdezs
275,000 mi? LOL, it's had a good life.... And it's a good candidate to try those different cleaning chemicals. Just be prepared though.... It's quite possible carbon buildup is what's keeping the compression
donjetman
It's possible the rings are just gummed up. That solvent stuff you had to the oil makes me nervous though. I've seen some LS oil pumps suddenly lose pressure.... And found little tiny pieces of grit in the pressure relief valve. It would also make me nervous if any little pieces made their way to a lifter. The filter should catch it, but then again on a cold start with high oil pressure, some oil bypasses the filter through the oil filter pressure relief valve above the oil filter on some, and built into the oil filter on others. I can't remember what you said your mileage was. If it's around 200,000 miles, it's probably a little bit of everything. (Rings, valve guides and valve seals)
Its not solvent stuff, its Valvoline Premium Blue "RESTORE" engine oil, developed by Valvoline for Cummins for a piston ring sticking problem they have.
I did a lot of reseach.
rdezs
Sounds better than the one quart of engine flush I think they still sell.
L
lspann3525
Spent some more time under the truck today and noticed the passenger side rack and pinion boot is wet this could be what's causing the front cover to be oily
donjetman
I feel your pain, mine's doing it on the drivers side :(
L
lspann3525
Did you use the proper tool to center the timing cover when you had it off for the seal? Sort of necessary for the front and rear main seal on LS engines....
Front and Rear Cover Billet Alignment Tool
https://a.co/d/6BYWsUm
Quick Question I went with the Dorman Rear Cover that had the seal already installed and I didnt use the alignment tool I just made sure the rear crankshaft seal was good all the way around . The instructions called for me to use a dorman alignment tool but looking at how the dorman tool works its no different than just placing the cover on the crank and gently pushing the cover. The dorman tool just sits on the rear face of the crankshaft. But I just learned that some guys install the cover without the seal and use the alignment tool to align it. Im considering redoing mine and installing new cover gasket and seal pressing it in after its been aligned with the tool.
Anyone else out there use the dorman rear cover without alignment tool??? I just dont see how the dorman tool can align the cover when the tool doesnt go around the crankshaft
rdezs
The proper alignment tool slides rather snugly around the end of the crankshaft, and also fits rather snugly in the seal bore in the housing. So yeah, with the proper alignment tool you install the rear cover without the seal installed. Then when you're done, you can use the same alignment tool to gently tap the rear seal in. Note that from the factory the rear seal is almost flush with the outside edge of the rear cover. It's okay and often advisable on higher mileage engines, to go ahead and tap the seal that extra 3/16 of an inch in. It will bottom out against the flange, and the seal will ride on a section of the crank that is like new, never had a seal rubbing on it.
rdezs
I did NOT use any alignment tool when I did the rear main seal/cover (2018) and front cover/seal (last summer). No leak
Hopefully it lasts.... I had to redo a rear main seal, about 8,200 mi after the previous owner did it without the tool. Didn't leak much, but I always found a droplet then some dampness..... Below picture is what I found
The seal itself is spring loaded, it will seal a while if not actually centered properly.... But it definitely won't last as long as it should.
mcguire7
