L83 TO L86 INTAKE, THROTTLE BODY OPTIONS
BigPac
picked up a used l86 intake manifold for 100$ and looking into different throttle bodies, i know the acdelco 12669871 for $403 off the 6.2 is standard, but amazon has oem 12673449 for $155 CDN. I believe it needs the adapter to work. But $$ its still cheaper. Any one have any experience ?
You get what you pay for, AT BEST. Amazon has many 3rd party vendors who substitute cheap knockoffs for OEM GM parts.
B
BigPac
OPPS , 12669871 for $403 off the 6.2 is THE 95MM but amazon has oem 12673449 for $155 CDN ITS ONLY 80MM
katech ports oem throttle body's, so this is a plus/plus and it's plug-n-play
I put one on my silverado in 2019, no issue's
GM Genuine Parts 12678223​
87mm $187
I’m looking forward to doing this swap on my suburban. I ordered a ported setup from chuy454 and i believed that’s the part number TB it comes with.
Chuy does really good work
First time customer and I was not disappointed! Great service. Removal & install was very easy. The hardest part was manual cleaning the intake valves . I’m glad I put on a catch can shortly after purchasing it.
B
BigPac
How did you manually clean the intake valves, what did you use ?
Lechez71
