L83 TO L86 INTAKE, THROTTLE BODY OPTIONS
How did you manually clean the intake valves, what did you use ?
If it’s really bad, definitely source out a walnut blaster. I just rotated the motor and used chemtool b12 to soak the valves that were closed. Agitated with miscellaneous bottle cleaner brushes and took 3/8 fuel hose adapted it to a shop vac to suck up fluid.
Jongrreat
