EddieC
- Joined
- Aug 9, 2014
- Posts
- 702
- Reaction score
- 552
Pillar covers have to come off to remove the dash trim and air bags are inside behind the pillar covers and all along the roof from front to rear doorsAnd a followup, the bases of the pillar covers appear to be free of the ends of the frontmost narrower dash cover panel so can I expect to be able to remove the dash cover panel without messing with the pillar covers?
The pillar covers and the panel appear to butt against each other,
So does the electrical system need to be drained down because of the proximity of the air bags?Pillar covers have to come off to remove the dash trim and air bags are inside behind the pillar covers and all along the roof from front to rear doors
no not unless you are trying to remove a airbag, you can work around themSo does the electrical system need to be drained down because of the proximity of the air bags?
Now that I took them off I see why. The depressed edges of the dash panel extends under the pillar covers.The pillar covers are easy to remove one screw and then it's just clips
