Lowered 21+ T1xx: Post Em Up
lakaw
Wichita, KS
KMeloney
If you get a chance, could you measure the clearance between the trailing arm and the ground? LOOKS like about 2".
I only want a 2/3 drop. Will this result in the trailing arm being higher off the ground than what you have in your setup?
Is that your truck in your avatar pic? If so, where are full pics of it in the '21+ section?!
lakaw
Wichita, KS
It is!! it's the only pic I have currently. I want to get it lowered before posting pics. Weather is ****** here, so it's going to need a detail too. Where is everyone posting pics?
KMeloney
Wherever you want! Start a new thread in General, or post a pic in the “black wheels” thread in Exterior, or put one in any thread about roof racks… JUST POST SOME PICS!
juice1s
Cicero,il
I don't remember the exact measurement but it was a little bit over 2". The arm will sit a little bit higher if you do not go that low but not by much.
olyelr
Elk Rapids, MI
The lower control arms will change a little bit, but they only go up and down with height changes on the differential side…at the tires they stay the same height (unless you change tire size).
Z71JimmyK
