2011 Tahoe/Real axle bearings Timken versus stock
rdezs
They asked to hold on to it till Tuesday afternoon, because of the holiday. (At GM's corporate offices) Sent wife home in a loaner....at their expense. (They sold us the vehicle about 7 years ago) I called and asked what the hell, they said they think they have a VIN and titling issue, but they're not sure yet. Not exactly sure what that means yet
rdezs
"Just because a new model has begun production, doesn't mean the old one cannot continue for a time on another line to use up their parts"
That was actually mentioned. They want to verify the VIN derivatives. Something about the actual components that were used.
I just ran your VIN through my secondary source and it says your truck was assembled on 11-22-2013. This makes more sense with your VIN. Usually when I see trucks made towards the end of the model year they have sequence numbers that usually start in the 300000s or 400000s.
1GYS4BEF5ER226585
Vehicle:
Listed Below
Year:
2014
Build Date:
2013-11-22
RPO Description
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL MULTI-DIRECTIONAL P/SEAT ADJR(AG2)
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
AJ7 RESTRAINT SYSTEM FRT SEAT, INFLATABLE, DRIVER AND PASSENGER, FRT & SIDE INFL RST FRT & SI(AJ7)
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0)
AL4 SEAT,REAR,BUCKET RR BKT ST(AL4)
AN3 SEAT FRT, INDIVIDUAL/NON-BKT INDIVIDUAL FRT SEAT(AN3)
AP3 LOCK CONTROL REMOTE, KEYLESS ENTRY, START REMOTE KEYLESS ENTRY & ENGINE START(AP3)
ARL PLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL)
ARS ADJUSTER RR REAR SEAT, POWER, STOWABLE PWR STOWABLE RR ST ADJ(ARS)
ASF RESTRAINT ROOF SIDE, LH & RH, INFLATABLE LH & RH ROOF INFLATABLE RESTRAINT(ASF)
AS3 SEAT,REAR UTILITY R/SEAT(AS3)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AXN IDENTIFICATION 9.5" LIGHT DUTY BEAM 9.5" LIGHT DUTY BEAM(AXN)
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
BQ2 FLEET INCENTIVE - AVIS CORP (C/D/E/F/G/H/J/K/L/N/M/U/W/Z-TRK CKGMLPST)
BS1 INSULATION,ACOUSTICAL INSULATION PKG(BS1)
BVU STEPS, RUNNINGBOARD SIDE, MOLDED, BLACK SIDE STEPS/RUNNINGBOARD(BVU)
B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
B58 COVERING,FLOOR MATS,FRONT AND REAR,CARPETED INSERT CPT INS FLR MATS(B58)
B8W VEHICLE GM - PROD WEEK 47
B85 ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING BELT RVL MLDG(B85)
CF5 ROOF,SUN,GLASS SLIDING,ELECTRIC ELEC SUNROOF(GLASS)(CF5)
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
C25 WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
C36 HEATER,AUXILIARY AUX HTR,RR(C36)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C6A GVW RATING(7300 LBS) 7300 LB GVWR(C6A)
C69 AIR CONDITIONER,RR AUX RR AUX A/C(C69)
DCP PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE DIRECTIONS & CONNECTIONS SERVICE PKG(DCP)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
DH6 MIRROR,INSIDE,VISOR VANITY,RH AND LH(ILLUM) ILLUM S/S MIR(DH6)
DK8 CONSOLE ROOF INTERIOR, DELUXE ROOF CONSOLE(DK8)
DL3 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR ELEC HEATED O/S MIR(DL3)
D07 CONSOLE,FRONT COMPARTMENT FLOOR(CUSTOM) CUSTOM F/CMPT FLR CNSL(D07)
EF7 COUNTRY UNITED STATES OF AMERICA (USA) U S A(EF7)
E52 BODY EQUIPTMENT ONE PIECE LIFT GATE WITH LIFT GLASS BOD LIFT GATE W/GLASS(E52)
E61 LIFTGATE, POWER PWR LIFTGATE(E61)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FHS VEHICLE FUEL GASOLINE E85 E85 GASOLINE VEH FUEL
FLT SALES PROCESSING - OPTION
GMQ RADIO AM/FM STEREO, SD NAV, DVD-ROM, CAF, USB, RSA, VOICE REC, AUX JA STEREO W/DVD,NAV,CAF,USB,VOICE REC,AUX JACK(GMQ)
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
G69 LEVEL CONTROL AUTO AUTO LVL CONT(G69)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
I14 ENGINEERING YEAR 2014 ENGINEERING YEAR 2014(I14)
JD9 BRAKE VAC POWER, 17" DISC/DISC, W/VSES, 7700 LBS 7700 LB VAC PWR BRAKES(JD9)
JF4 PEDALS ADJUSTABLE, POWER PWR ADJ PEDALS(JF4)
JL4 CONTROL ACTIVE BRAKE ACTIVE BRAKE CONTROL(JL4)
KA6 HEATER,RR SEAT REAR SEAT HEATER(KA6)
KB6 HEATER SEAT, COOLING, FRT COOLING FRT ST HTR(KB6)
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
KNP COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
KW1 GENERATOR,160 AMP 160 AMP GEN(KW1)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
L94 ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 6.2L, SFI, ALUM CYL DEACTIVATION, GM 6.2 W/CYL DEACTVN(L94)
MYC TRANSMISSION AUTO 6 SPD, HMD, 6L-80 6-SPD A/TRANS(MYC)
NP7 STEERING COLUMN(EXPORT) STRG COL(NP7)(EXPORT)
NR3 TRANSFER CASE ALL WHEEL DRIVE (AWD), OPEN DIFF, SINGLE SPEED AWD SINGLE SPD TRANSFER CASE(NR3)
NT7 EMISSION SYSTEM FEDERAL, TIER 2 TIER 2 FED EMIS(NT7)
NZ4 WHEEL SPARE FULL SIZE, 17" STEEL FULL SIZE SPARE WHL(NZ4)
N30 STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30)
P56 WHEEL 22 X 9.0, ALUMINUM, CHROME CHR ALUM WHL(P56)
QST TIRE ALL P285/45R22 BW TL AL2 TIRE(QST)
R6F CONTROL - SALES ITEM NO. 06
R9N CONTROL - SALES ITEM NO. 89
SAF LOCK SPARE TIRE, HOIST SHAFT SPARE TIRE LOCK HOIST SHF(SAF)
TGA LANGUAGE CONTROL ENGLISH, FRENCH, SPANISH ENGLISH-FRENCH-SPANISH LANGUAGE CONTROL(TGA)
TL1 GRILLE,SPECIAL SPECIAL GRL(TL1)
TQ5 CONTROL INTELLIGENT HIGH BEAM INTELLIGENT HIGH BEAM CONTROL(TQ5)
T74 HEADLAMPS CONTROL AUTOMATIC, DELAY AUTO HLDP(T74)
T96 LAMP,FRONT FOG FRT FOG LP(T96)
UBS DIGITAL AUDIO SYSTEM S-BAND AND TRAFFIC S-BAND & TRAFFIC DIGITAL AUDIO SYS(UBS)
UD7 SENSOR INDICATOR NEAR OBSTACLE DETECTION/REAR PARKING ASSIST RR PARKING ASSIST/OBSTACLE DETECTION SENSOR(UD7)
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
UFT SENSOR INDICATOR SIDE OBSTACLE DETECTION SIDE OBSTACLE DETECTION SEN(UFT)
UG1 OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
UJM TIRE PRESS INDICATOR MANUAL LEARN MANUAL LEARN TIRE PRESS IND(UJM)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
UK6 RADIO CONTROL REAR SEAT & EARPHONE JACKS RR ST AUDIO(UK6)
UPF WIRELESS INTERFACE SHORT RANGE, VOICE REC VOICE REC WIRELESS INTERFACE(UPF)
UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER PREMIUM SPKR SYS W/SURROUND AMP(UQS)
USR RECEPTACLE USB USB PORT/RECEPTACLE(USR)
UVC CAMERA REAR VIEW REAR VIEW CAMERA(UVC)
UVD SWITCH STEERING WHEEL, HEATED HEATED STRG WHL SWITCH(UVD)
U42 ENTERTAINMENT SYSTEM REAR SEAT,SINGLE DISPLAY,REM CONTROL W/HEADPHONE ENTERTAINMENT SYS(U42)
U84 ANTENNA BODY SIDE WINDOW, RADIO BODY SIDE WINDOW RADIO ANT(U84)
VFF VIDEO FORMAT REGION 1, NTSC REGION 1 VIDEO FORMAT(VFF)
VGD FASCIA FRT, CUSTOM, BODY COLOR BODY COLOR FRT FASCIA(VGD)
VGE FASCIA RR, CUSTOM, BODY COLOR BODY COLOR RR FASCIA(VGE)
VH9 ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VQ2 FLEET PROGRAM - DEALER ASSISTANCE, HOLDBACK NOT APPLICABLE
VR4 TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4)
VT7 OWNERS MANUAL ENGLISH LANGUAGE ENGLISH LANGUAGE OWNERS MANUAL(VT7)
VX7 FLEET PROGRAM - NON-REPURCHASE, LONG TERM DAILY RENTAL
VZE VIN MODEL YEAR 2014 VIN MODEL YEAR 2014(VZE)
VZ2 CALIBRATION- SPEEDOMETER A SPEEDO CALIBRATION(VZ2)
V1K BAR LUGGAGE CARRIER,CENTER CROSS LUGGAGE CARRIER(V1K)
V54 CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
V76 HOOK,FRONT TOW FRT TOW HOOK(V76)
V8D VEHICLE STATEMENT US US VEHICLE STATEMENT(V8D)
XL7 FREQUENCIES RATING 315 MHZ LONG DISTANCE 315 MHZ FREQ(XL7)
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
YE9 CONVENIENCE PKG COMFORT & DECOR LEVEL #3 COMFORT & CONVENIENCE PKG #3(YE9)
Y91 LUXURY EDITION OPTION,"LE" LUXURY EDITION/"LE" PKG(Y91)
ZRS TIRE SPARE P265/70R17-113S SPARE TIRE(ZRS)
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
Z75 CADILLAC BRAND IDENTIFICATION CADILLAC(Z75)
Z82 TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
Z95 CHASSIS PACKAGE MAGNERIDE MAGNERIDE CHASSIS PKG(Z95)
1SB PACKAGE-OPTION 02 (1SB)
1SZ PACKAGE OPTION- (1SZ)
19I INTERIOR TRIM COLOR (19I)
194 TRIM COMBINATION,BLACK LEATHER (194)
41U EXTERIOR COLOR,PRIMARY (41U)
6LM COMPONENT FRT LH COMPUTER SEL SUSP SUSP(6LM)
7LM COMPONENT FRT RH COMPUTER SEL SUSP (7LM) SUSP(7LM)
I think you are just mistaken in saying you put a 2.992 inch wheel bearing in the Cadillac. I've got four 9.5" axles here for GMT900s and they all take the same wheel bearing as the 8.6" axle. AAMs website confirms this, GMPartsGiant also confirms this, even when I include your VIN.
Keep us posted, stranger things have happened!
RoryCup
