2011 Tahoe/Real axle bearings Timken versus stock
..... But something does have me thinking. The Escalade was built in November 2014. I've noticed on some drivetrain parts, like the timken bearings, they show the applications through the 2013 model for some reason. I have not measured my ring gear.... I know I'm 2015 they had a larger ring gear.... But I still have the 14 bolt cover.
You didn't look at any of the links or part numbers did you?
You didn't specify which picture of mine you wanted me to look up the RPO codes for either.
It's not uncommon for the aftermarket to omit a year. In our case they are following the chassis based on the 1500 pickups.
rdezs
Didn't have time to fully look through the whole page this morning. I was curious about the RPO code on that axle where the flange is real close to the axle tube. I see that on the 8.5 axles but not the 9.5. The 9.5 seems to have more spacing away from the axle tube.
I'll look at that page this afternoon, it had a lot of data on it.
It came from a 2011 Escalade:
1GYS3KEF3BR252701
1SD PACKAGE OPTION 04
1SZ DISCOUNT OPTION PACKAGE
415 TRIM COMBINATION LEATHER, VERY LIGHT LINEN/COCOA ANILINE, (05) (08)
41I INTERIOR TRIM VERY LIGHT LINEN/COCOA (I) (08)
6LL COMPONENT FRT LH COMPUTER SEL SUSP (6LL)
7LK COMPONENT FRT RH COMPUTER SEL SUSP (7LK)
98U PRIMARY COLOR EXTERIOR, WHITE DIAMOND (02)
A31 WINDOW POWER OPERATED, ALL DOORS
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONAL
AJ1 WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS
AJ7 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT & SEAT SIDE
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AL4 SEAT RR BKT
AN3 SEAT FRT, INDIVIDUAL (NON BKT)
AP3 LOCK CONTROL, ENTRY REMOTE, KEYLESS ENTRY, START
ARL PLANT CODE ARLINGTON, TX, USA
ARS ADJUSTER RR REAR SEAT, POWER, STOWABLE
AS3 SEAT REAR UTILITY
ASF RESTRAINT ROOF SIDE, LH & RH, INFLATABLE
AU3 LOCK CONTROL SIDE DR, ELEC
AXN IDENTIFICATION 9.5" LIGHT DUTY BEAM
AXP VEHICLE TYPE MULTI-PURPOSE PASSENGER VEHICLE
AYE RESTRAINT HEAD, RR SEAT, ANILINE LEATHER (WITH DVD)
B30 COVERING FLOOR CARPET
B39 COVERING FLOOR CARPET, LOAD FLOOR
B58 COVERING FLOOR MAT, FRT & RR, CARPETED INSERT
B85 MOLDING B/S EXTERIOR, BRIGHT
BRS STEPS, RUNNINGBOARD SIDE, RETRACTABLE, POWER
BS1 INSULATION ACOUSTICAL PKG
C25 WIPER SYSTEM RR WINDOW, INTERMITTENT
C36 HEATER AUXILIARY
C49 DEFOGGER RR WINDOW, ELECTRIC
C5Z GVW RATING 7, 200 LBS
C69 HVAC SYSTEM RR AIR CONDITIONER
CF5 ROOF SUN, GLASS, SLIDING, ELEC
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
D07 CONSOLE FRT COMPT, FLOOR, CUSTOM
DCP PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE
DD8 MIRROR I/S R/V LT SENSITIVE
DH6 MIRROR I/S FRT VAN LH & RH, SUNSHADE, ILLUM
DK8 CONSOLE ROOF INTERIOR, DELUXE
DL3 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR
DNU EQUIPMENT ADDITIONAL DVD SCREEN
DT4 ASHTRAY CIGARETTE LIGHTER
E2C ORDER TO DELIVERY EXPEDITE TO CUSTOMER
E52 BODY EQUIPMENT ONE PIECE LIFT GATE WITH LIFT GLASS
E61 DOOR RR LIFTGATE, POWER
EF7 COUNTRY UNITED STATES OF AMERICA (USA)
FE9 CERTIFICATION EMISSION, FEDERAL
FHS VEHICLE FUEL GASOLINE E85
G69 LEVEL CONTROL AUTO, AIR, HD
G80 AXLE POSITRACTION LIMITED SLIP
GMQ RADIO AM/FM STEREO, SD NAV, DVD-ROM, CAF, USB, RSA, VOIC E REC, AUX JACK
GU6 AXLE REAR 3.42 RATIO
HNE EQUIPMENT HEAT & COOLED CUPHOLDERS
JD9 BRAKE VAC POWER, 17" DISC/DISC, W/VSES, 7700 LBS
JF4 PEDALS ADJUSTABLE, POWER
JL4 CONTROL ACTIVE BRAKE
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
KA6 HEATER SEAT, RR
KA9 HEATER STEERING WHEEL
KB6 HEATER SEAT, COOLING, FRT
KC4 COOLING SYSTEM ENG OIL
KNP COOLING SYSTEM TRANS, HD
KW1 GENERATOR 160 AMP
L94 ENGINE FLEXIBLE FUEL, (GAS/ALC), 8 CYL, 6.2L, SFI, ALUM CYL DEACTIVATION, GM
MYC TRANSMISSION AUTO 6 SPD, HMD, 6L80
N30 STEERING WHEEL DELUXE
NT7 EMISSION SYSTEM FEDERAL, TIER 2
NZ4 WHEEL SPARE 17 X 7.5, J, STEEL, DESIGN 2
QST TIRE ALL P285/45R22 BW TL AL2
R7V CONTROL SALES ITEM NO. 46
R9I CONTROL SALES ITEM NO. 84
R9N CONTROL SALES ITEM NO. 89
R9Z CONTROL SALES ITEM NO. 100
S85 WHEEL 22 X 9, ALUM, CHROME, FLANGED
SAF LOCK SPARE TIRE, HOIST SHAFT
SLL SALES PROCESSING SOLD ORDERS
T4Q HEADLAMPS LED, RH RULE OF ROAD, FMVSS
T74 HEADLAMPS CONTROL AUTOMATIC, DELAY
T96 LAMP FOG, FRT
TGA LANGUAGE CONTROL ENGLISH, FRENCH, SPANISH
TL1 GRILLE SPECIAL
TQ5 CONTROL INTELLIGENT HIGH BEAM
U42 ENTERTAINMENT PKG REAR SEAT, SINGLE DISPLAY, REM CONTROL, AUX JACK 2-WIRELESS DUAL CHANNEL HEADPHONES
U84 ANTENNA BODY SIDE WINDOW, RADIO
UBS DIGITAL AUDIO SYSTEM S-BAND AND TRAFFIC
UD7 SENSOR INDICATOR REAR PARKING ASSIST
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1
UFT SENSOR INDICATOR SIDE OBSTACLE DETECTION
UG1 OPENER GARAGE DOOR, UNIVERSAL
UJM TIRE PRESS INDICATOR MANUAL LEARN
UK3 CONTROL STEERING WHEEL, ACCESSORY
UK6 RADIO CONTROL RR SEAT & EARPHONE JACKS
ULT APPEARANCE PACKAGE CADILLAC ESCALADE, PLATINUM
UPF WIRELESS INTERFACE SHORT RANGE, VOICE REC
UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER
USR RECEPTACLE USB
UVC CAMERA REAR VIEW
V1K BAR LUGGAGE CARRIER, CENTER CROSS
V54 LUGGAGE CARRIER ROOF, PAINTED
V8D VEHICLE STATEMENT US
VFF VIDEO FORMAT REGION 1, NTSC
VGD FASCIA FRT, CUSTOM, BODY COLOR
VGE FASCIA RR, CUSTOM, BODY COLOR
VH9 ENVELOPE OWNER INFO MAN
VPV HANDLING CHARGE ARLINGTON ASM TO KERR INDUSTRIES, ARLINGTON, TX AND RETURN TO ARLINGTON ASM
VR4 TRAILER HITCH WEIGHT DISTRIBUTING PLATFORM
VT7 OWNERS MANUAL ENGLISH LANGUAGE
VZ2 CALIBRATION SPEEDOMETER A
XL7 FREQUENCIES RATING 315 MHZ, LONG DISTANCE
Y91 MERCHANDISED PKG LUXURY EDITION
YD3 AXLE (BASE EQUIP) FOR SCHEDULING GVW PLATE
YD5 SPRING FRONT BASE EQUIPMENT
YD6 SPRING RR, BASE EQUIPMENT
YE9 CONVENIENCE PKG COMFORT & DECOR LEVEL #3
Z75 CONVERSION NAME PLT CADILLAC
Z82 TRAILER PROVISIONS SPECIAL EQUIPMENT, H.D.
Z95 CHASSIS PACKAGE MAGNERIDE
ZRS TIRE SPARE P265/70R17-113S
ZY1 COLOR COMBINATION SOLID
ALL of the GMT900 1500s are like that. You know how I know, besides the pictures and seeing them side by side? There's only one part number for the parking brake anchor block. That and the dust shield is what bolts up to that. The one for the '09 Hummer is way different.
I kinda think I know why you discount the photo with the tape measure on both axles. I was in the heavy equipment parts business and like you, saw tons of parts that were only minutely different from one another. Our air spring catalogs seemed like they were a foot thick back then!
I would normally find it odd that GM put the AXN on an AWD truck when they hadn't done so for many years but since it was the end of the model run and the new generation was using a different axle, it makes sense that they would use up all their extra parts. Saw this with the GM G-Bodies in the 1980s.
rdezs
But Hummer H2 I have with the same 2.996 in axle bearing is a 2003.
Below is my list of RPO codes. The date of manufacture is November 2014. It was sold and titled as a 2014 model.... But I think it's prudent to assume many of the 2015s were being manufactured prior to that date? I may in fact have an oddball in between model years. Last year I was at my local dealer parts counter with my rear u joints in hand. They told me those aren't the correct ones for a 2014.... That I must have a 2015. Showed him my VIN number off my insurance card, he looks it up and it says 2014. WTH?
Are you saying that you used 3" diameter wheel bearings in your Cadillac's axle?
Your u-joints are 1355s right? The K2s are 1415s.
Production of the 2015s began in January 2014 and sales began in April 2014.
rdezs
Houston, we have a problem. I did some more digging. While Wikipedia can be questionable, they stayed the 2015 model started production in January 2014, and went on sale in April 2014. ...
Some more digging turned up this article from general motors Canada that confirms the above:
General Motors Canada
I shared this info with my contact at my local dealership. They're familiar with the issues of locating correct part numbers with my VIN. Said they'll get back with me probably Monday or Tuesday after some research.... But yeah, they agree there is an obvious problem here. Mine was built in Arlington Texas 11 months after production of the 2015 started at the same factory.
Even the platform is different from the 2010 to 2014 models.
rdezs
That was quick. Since I'm at work the wife is taking the Escalade down to the dealer. They want to take some specific wheelbase measurements and such, and get some numbers off it. They suspect it is the platform GMT K2 XL, and will be able to confirm with some measurements in whatever else they're looking for. This is going to be a huge headache at the department of motor vehicles I'm afraid. They were able to pull up an image of the certificate of origin from Arlington. Something tells me the error is on that certificate. They didn't want to commit to anything yet.
Can you post a photo of your truck again? How about those ones of the brakes and any undercarriage photos?
Just because a new model has begun production, doesn't mean the old one cannot continue for a time on another line to use up their parts.
rdezs
Will do when I get home. My wife said they've been crawling all over it for about an hour. She is watching through the window drinking their free coffee. She said the sales managers involved in the inspection as well. Starting to wonder what kind of Frankenstein I've got....
brian70068
