Rear door seals doesn't hold the dirt from the outside
deathfry
hi folks
tahoe 2008
It seems that all the dirt from the streets doesn't properly get hold by the seal and it appears inside the door (see photos). looks like there is a gap between the door and the seal. Any way to fix that? Thanks in advance
GMT800 SUV/Trucks
I may not be seeing the pics right but if you have slush and salt and dirt build up and open/close the door, some of that will get by a seal during the open/close process. Have you thought about replacing the entire door opening seal? Is it on both doors? has it ever been wrecked? Front door? rear door?
D
deathfry
Well, I suppose dirt gets in when doors are closed. And after opening process I just inspect it :D I guess it is because of: 1) old seal - seal gets "shrink" in size 2) the door itselft doesn't close too tight - it may be fixed by adjusting the so called striker.
It seems that I am the only one who rides through fire and storm dirt and salt and take care about cleanliness of doors ))
No wreckage (guessing, just bought it), only both rear doors
You're not alone, caring about cleanliness, but you may need to replace the outer door seals to cure the problem. If the door alignment isn't right, fix that too.
GMCChevy
Senior Member
A new seal would probably help a but that's one of the down sides to how GM overlaps their rear door like that.
petethepug
Michael
SoCal
Anyone know where the thread is of the guy who filled the door seal interior cavity with round foam piping to rejuvenate the seals?
petethepug
Michael
SoCal
Reminded me of kindergarten making necklaces out of macaroni noodles. Not hard at all as long as you’re not too distracted eating the paste.
For your next question, no, I haven’t. But it smelled like ke it might taste ok.
