Jobi-Wan Kenobi
- Joined
- Aug 27, 2022
- Posts
- 217
- Reaction score
- 298
Think we do indeed have an electrical issue here. Gauge was reading normal this morning.
My 5.3 (01 Silverado) isn't coming up to temp either. Barely any heat in the cab. It's been a problem for a couple of years and is only an issue in the winter. Replaced the radiator last year due to end tank cracks. I, too, am leaning toward a stuck thermostat but will wait to see how your problem is resolved.
@iamdub solved that issue by using an old orifice from a tpms sensor. Said it was perfect.Be sure to use an OBD tool to verify the engine temp. This could be a thermostat problem -- incorrect temp or defective -- or the (aftermarket?) radiator's port that goes to the surge tank has too large of an orifice and the engine doesn't heat up. There are threads on here about that.
