Drives for 1 city block
EdTuck
I have a 2017 GMC Yukon SLT 4 wheel drive 5.3 liter engine w/trailor package.
It starts right up, put in drive it goes. Get a block down the road and it's almost like it's in neutral. No reverse, put it in 4 wheel drive NOThIng.
Let it sit for 10 minutes and all works. Reverse, 4 wheel drive all good for a block.
Is it the transmission?
Would I be wasting my time to change filter and fluid?
Help
NickTransmissions
Sin City
The transmission bench
Help
How many miles on that transmission?
What DTCs (if any) have been set/stored?
What does the fluid smell like on the dipstick?
Is fluid level correct?
Most likely it needs to be rebuilt, assuming fluid level is correct. Drop the pan to confirm/deny so you know - maybe the filter neck is cracked or filter is clogged....If you have a ton of burnt clutch material on the pan bottom, put the pan back on w/a few bolts and pull it for overhaul.
Visit my 6L80 Information thread for video instructions, tech resources, parts list and more - link is in my signature line.
E
EdTuck
Thanks
I will take pan off tonight, unfortunately there is no dip stick.
E
EdTuck
Gotcha....What codes (if any) does it have and how many miles o the transmission?
150k and u are right there is a dip stick, fluid level is a little high and it is a brownish read color. No code or no errors no engine light.
NickTransmissions
Sin City
Yep, I believe most of the trucks had dip sticks, at least w/the six speeds. Let us know what you find in the pan...Don't forget to check the filter for cracks around the neck or anywhere else on the body. If you see a lot of burnt clutch matter, put the pan back on with a few bolts and yank it out for overhaul.
E
EdTuck
I got held up for a while, going to drop pan with in the next few days.
2dr_lowhoe
