Squeak from Serpentine Belt Area
black tahoe 08
I have an 08 Tahoe, new to me about 2 months ago. The serpentine belt is squeeking and I can't figure out how to stop it. I have changed the alternator, idler pully, tentioner, tensioner pully, and belt. Still driving me crazy
jfoj
My 2005 has a squeaking A/C clutch bearing. As I tell people, I have a tweety bird under the hood!
As mentioned, put the A/C belt and see what happens.
donjetman
Could be the crank outer pulley separating from the inner hub which causes a misalignment. The inner and outer parts are held together by rubber that deteriorates with age. I changed mine recently as preventative mx.
GMT800 SUV/Trucks
Good call.
It's time to take a mechanic's stethoscope or long extension to isolate this sound. If you have long hair, get it out of the way. Stick one end in your ear and touch the various parts to isolate the source of the sound. Be careful.
Welcome to the Forum from NH.
Pics of the truck, please.
kbuskill
NE. FL.
You said you have only had it about 2 months. Do you have any maintenance records?
It is also possible that the power steering pump pulley is slightly out of alignment which will cause the belt to squeak.
Stick a straight edge across the face of the various pulleys to see if there is any misalignment.
dyce51
I chased and chased a "squeak" on one of the accessories on cold start one time...ended up being the water pump...
sbt2003
