Questions about shocks and struts.
Trilla_one
FL
Less body roll and less bounce. Could just be me.
Is it less bumpy now than before? Are you on stock wheels?
Mine rides similar to how you described at the beginning. Like you I got it later in it's life without knowing the suspension history. It also came with a set of 22s which may or may not be apart of the problem. It's not a terrible ride but it always has this slightly "unsettled" feeling, especially at slower speeds. It's still solid and comfortable overall though. I would have to ride in another truck to see if it's any different.
I replaced shocks on a 95 Maxima in the past that had a lot of bounce and it solved the problem. I did the same on an 04 Maxima that had a bumpy/harsh ride and it didn't. Not saying the shocks didn't need replacing due to mileage but the bumpy ride was unrelated to them being old.
iboughtatahoe23
iboughtatahoe23
See I was replacing the shocks to hopefully mitigate the stiff ride, but it seems like these SUVs just have a stiff ride you know? It seems like they’re not really made for off-roading and bumps, but more for long stretches of highway.
Marky Dissod
... replacing the shocks to hopefully mitigate the stiff ride, but it seems like these SUVs just have a stiff ride you know?
If (for whatever strange reason) you find your ride too stiff,
then you should very seriously consider less-stiff coil springs.
'How much less stiff?' would be the question you'd need answered.
iboughtatahoe23
iboughtatahoe23
Want more absorbing for the ****** roads
Marky Dissod
Want more absorbing for the fukdtup roads
censership is so funking we tardid
If you do NOT care about improving handling, then
stay with 17" wheels, but if you can find LIGHTER 17" wheels, get 'em
replace your GoodYears (good for a year, as in, one good year ... get it?) with tires known for better ride quality,
like Continental TerrainContact H/T or Michelin Defender LTX M/S2, and don't pump them up past 36psi (under 30psi is a dangerously BAD idea)
very seriously consider 255/75R17, or 275/70R17 - taller sidewall will better protect against faulty asphalt
replace and generously lubricate every rubber bushing, eventually including the body-to-frame bushings,
possibly adding cushions to your suspension
make your vehicle lighter using parts from a hybrid Tahoe
iboughtatahoe23
iboughtatahoe23
How do you lube a bushing? Just slather some grease on it?
Has anyone inspected your body mount bushings? I recently had mine replaced, and they were in rough shape.
Shadfrmdabull
