Tahoe shifter cable
It will go in reverse and than a second later it seems to just fall out of the gear and won't move. I can get it P,N,D,3,2,1 it just won't stay in reverse.
you need to adjust the cable, the reason the shifter arm is so loose in his video is because the spring is popped out on the shifter arm, that is a separate issue unrelated to doing the adjustment.
J
jackmono
My husband change the transmission oil and he moved the shifter to get the pan out there was no C clip holding the shifter in the bracket and he couldn't get it to go in gear so we just thought something wrong with shifter cable so we bought a new one. It's routed the same way that I took it out I do notice that when it will go through all the gears up at the column and then I'll put it back in park and then when I go look at the lever by the transmission it's not all the way in the park I can still move it up. I've tried to adjust it I'm just doing something wrong I guess I just don't understand why it will hit reverse I'll push the gas and it will go backward and this falls out of the gear and won't move again
J
jackmono
Thank you for that video I have watched that video among other videos a zillion times I just do not understand what I'm doing wrong. Just when I think I got it it just slips out of reverse. Or it will act like it's in reverse the reverse lights will go on in the back but it won't engage the gear it won't move
take the cable off down at the transmission, then move it by hand and compare it's location to the cable connector. you either have it adjusted to far forward or to far back. I suspect too far back. you might want to get a helper to move the shifter while you are under the truck and feel it/look at it.
of course don't get rolled over, chock the wheels.....]
when you move the shifter arm at the transmission you will feel it "click" at each gear, I suspect how the cable is set currently it's not "clicked" into reverse so it pops out into neutral ? correct? if not then it is popping back into park in which case the cable would need to be adjusted the other direction.
it's going to be one way or the other..
CG11
