BATTERY/SECURITY/LOW FUEL etc...
Sorry for raising this from the dead again, but how did you solve your problem? I had the same issues but my airbag module looks like it's in great shape and doesn't change anything when disconnected.
He hasn’t been on since 2016. You should probably start a new thread.
02TAHOEswitch
I FIGURED IT OUT FOR MY 02 TAHOE. IT WAS THE STOP LIGHT SWITCH. I think. When I hold the brakes down in accessorie mode everything comes back on. I disconnected the switch and temp gage, fuel,airbag light and ring around PRND21 came back on. I will update after changing the switch. I also noticed that cruise control light works when messing with it as well.
02TAHOEswitch
... so here is all of it...
January 2014: fuel pump failed, replaced
January 2014: injector issues, replaced all injectors, fuel filter and regulator
March 2014: MSG Center shows SECURITY/BATTERY/LOW FUEL flashing, AIRBAG indicator goes on, FUEL Gage goes to zero: researched online, found post from GM Mechanic saying to isolate offending module just pull fuse. I pull SRS Fuse and all problems cease (of course airbag light is on)
May 2014: MSG Center shows SECURITY/BATTERY/LOW FUEL/SERVICE 4WD flashing, AIRBAG indicator on, FUEL Gage goes to zero, Temp gage appears to stay off, Gear selector indicator is out, ABS light on, and sometimes, at very slow speeds and in dry conditions ABS activates and vehicle does not stop: Pull ABS fuse 60amp, and all problems cease.
A few days later MSG Center shows SECURITY/BATTERY/LOW FUEL/SERVICE 4WD flashing, AIRBAG indicator on, FUEL Gage goes to zero, Temp gage appears to stay off, Gear selector indicator is out, ABS light on: I do more research and in my alldata account find a GM tech bulletin with all the same details saying check for battery cable voltage drop. I do and find POS is OK, NEG has a 2v drop. I order the AC Delco part, install and no change. But my interior lights are VERY bright now
I clean up (very well) the ABS Ground under drivers door: no change
I just discovered my OBD port has power but can't connect to ECU (works on other vehicles, have a backup. it also doesn't work)
Any help would be great.
02TAHOEswitch
Any luck?
I know this is an old post, but I didn't see any follow up?
z33garage
