Auto start/stop eliminator added
Big Mama
Virginia
Should there be a video link? I’m on my phone so sometimes I can’t see the link.
Jay P Wy
Natrona County WY
Don't know about a video but here is the web site. All this does is remember the switch position so if you turn it off when you restart the vehicle it will still be off.
Big Mama
Virginia
Thanks. Did you happen to look into the auto stop/DFM all in one eliminator? I’ve been eyeing them but haven’t made up my mind.
vwfast
Been running the Autostop eliminator in my 22 for almost 3 years. Works great and no issues whatsoever.
NELLY1947
Video on auto start/stop eliminator site was easy to follow. 15 minutes job, sand it works just fine with no codes.
I
my unit 2023 Yukon and my 2019 just keep your finger on tge push button till the dash reads "auto stop cancelled". The reason for this feature is if by accident the unit starts in your garage. Years ago I knew a couple in Florida who died cause they forgot to turn off the unit.
RST Dana
RST Dana
OH
I
the reason for the feature is emissions. My 21 will auto shut off from idle (even if I have been driving) when parked after a number of minutes.
ZKWBQD
I installed one of these on my Tahoe that was less than 3 hours old. I purchased the one that goes behind the dash. The override button still works. The difference is it permanently remembers your decision. This is a great safety feature that will help the engine last longer and improve safety.
Big Mama
Virginia
My last few drives I noticed something but I’m curious to see if it’s the same for others. I don’t have the eliminator.
If I come to a red light or stop sign and press the brake pedal enough to stop and hold the truck at a stop it doesn’t turn off. However, if i press the pedal completely it turns off. Can someone else try this and report back? I’m sure GM wouldn’t design it this way.
CG11
