Auto HVAC
My baby goes in the garage, no remote start for me. The point of this thread is that my '09 operation is what I expect. Wait till engine temp is high enough to blow warm air. Not just blow cold air from the jump.
weird never had that experience with any gm vehicle, i turn it on auto/manual, doesn't matter. when started it blows air it's doesn't "wait" for anything. on auto it may increase/decrease the fan speed to compensate for the desired temp throughout a drive but that's it.
And I would be pissed if it didn't blow air out the get go, normally in about 1/2 mile i'm getting some heat/warmth in any case
GMCChevy
Senior Member
My 2017 works that way, on auto with defrost on the fan stays low till it starts blowing heat then it speeds up. Which does make some sense because you're not getting that blasting of cold air at first.
lakaw
lakaw
Wichita, KS
Yeah, maybe the ‘09 fan comes on super low, but you definitely don’t get blasted until the air gets up to temp.
WalleyeMikeIII
Sunny and Snowy Minnesota
Just wondering if I'm missing a setting somewhere... On my '09 Denali when I set the hvac to auto @ 70°, when it is cold out, it would wait until the engine temp was high enough to blow warm air. This is my expected operation. My '24 with the same settings just blows cold air from engine start.
Anyone else experiencing this?
Mine, when cold (and it has been cold here), will blow air on low speed, until the engine warms a bit, then it ramps the fan up and blows warm air...I believe this is the designed implementation...give a little airflow on the windshield so your breath doesn't fog it up...but fan speed definitely increases from low as the engine (coolant, and thus the heater core) warms.
Garage2010
