Gas cap hissing. Can’t barely pump gas.
Also my long term fuel trims are reading -10 and -12 in both banks. Am I running lean? Could the clogged lines or bad purge valve vent solenoid cause this
Running rich. The PCM is taking away fuel (negative trims) because it's being told there's too much fuel by the O2 sensors. A bad purge valve can cause this, among other things, as can fuel contamination in the oil.
iboughtatahoe23
iboughtatahoe23
Yes, with the new canister and canister vent valve, purging in the described manor worked for me. A shop vac with the hose on the exhaust side might work as well. I applied air pressure for at least ten minutes until I saw no more charcoal coming out.
I tried doing that; blowing down the filler neck with a air compressor and the little slot above the filler neck, with the charcoal canister off nothing came out of the EVAP lines even when I set a slab of cardboard under it it looks like just some water came out a few drops
clublub69
