Truck won't crank
nonickatall
nonickatall
Germany
@rockola1971
I disassembled today the PCM. The connector was absolutely clean, no green crust.
I opened up as well the PCM and as well inside, it looks absolutely clean.
Yes I have a meter and I can work with it, I would appreciate your help very much.
I measured to ground at the fuse socket. On the terminal pointing to the front of the car, I have 90 ohm resistance. The other has no ground.
nonickatall
nonickatall
Germany
I have a friend how has the same truck. Can i swap the PCM, just to check if his PCM works, or do I have to program the Key Lock system or something else?
rockola1971
Indiana (formerly IL)
Have you done any work lately that involved installing any sheet metal screws or disassembly/removal of anything hard like a valve cover, alternator, master cylinder, etc? If so, thoroughly inspect around the part for a smashed, pinched wire harness. Also look for a wiring harness under the hood that is rubbing up against metal and has wire insulation damaged. If nothing at all those then I suspect your problem is internal of the PCM since a fuse is blowing to it.
rockola1971
You should be able to do a direct PCM swap. The PASSLOCK is in your BCM so no problems there. There may be some accesories like AUTO AC or maybe the radio that may not work correctly or not at all but the vehicle should start with your friends PCM. A BCM is programmed to the PCM but I believe thats only for certain features inside the vehicle to work.
nonickatall
nonickatall
Germany
No i did very less in the last half year on my truck. Only known problem is that my fuel pump is leaking. I smell gasoline when i drive. I have a new pump here, but wasn't able to fix that problem yet. Aside from that, everything worked, an the engine runs good.
nonickatall
nonickatall
Germany
I talked to my buddy and he will come tomorrow with his PCM, so i can check if the PCM is the problem.
Do you think the fuel pump can cause the problem by shortcut, because of the fuel leak?
rockola1971
Fuel pump leak (I assume you mean oring at the tank or broken hose connection at the tank) aint causing you to not get 12v at your terminal S at the starter. It also isnt causing PCM B fuse to blow.
rockola1971
Ok I tracked down some schematics for you 2006 Esky. Igntion E fuse is the feed for the control circuit for your starter RELAY coil. PCM B goes to the PCM. Ignition A is the feed for your ignition switch. First check those fuses (We know the PCM B fuse is blowing) then I would pull that Fuse Block up off its base (After disconnecting battery) and check for the green crusties and other foreign material or rodent damage. You still could have a damaged PCM and/or other problem like the fuseblock but at this point I dont believe your problem is in the ignition circuit including your IGN Switch since PCM B fuse is not related to that circuit.
nonickatall
nonickatall
Germany
I swapped the PCM from the buddy, but as soon when I switch on ignition the PCM B fuse blows.
@rockola1971
I will look on on the information of your last post, later ..
Thank you very much for your help...
nonickatall
nonickatall
Germany
I had checked concerning the fuse box. Looks all normal without moisture or green crust...
Ta6112
