osirus5164
- Joined
- Feb 9, 2025
- Posts
- 27
- Reaction score
- 10
So, I'm putting everything back together and the sub assemblies are pretty close. I was curious what everyone's opinion was on case savers vs anti clunk spring. Yes no meh?
Second, is load release springs. They're on the table but I would need to order new springs. Crusted in clutch material.
Another curiosity, front pump. So I see that the 073 casting is the same through years aside from the o ring vs wedge seal. My dude has damage to the pump body side but the stator inside is pretty decent. There's lots of options available for the body but they are all boring style. Does that machining for the o ring make it unusable in wedge seal application? I am going to be calling a guy who was recommended as far as surfacing my old one but I'm still curious just in case. Is there anything that I would have to take into consideration with the loss of material or is it negeglable and rebuild as normal? Thanks guys!
Just for kicks, I'll tag @NickTransmissions . Maybe you'll see this while you're having a cup of coffee in the morning and I'll be privileged with some of that valuable insight that I've used in this project thus far.
