New member: 2025 Tahoe High Country
T
tyet
I'd like to know this too as I'm getting the same upgrade. But not super worried about it... I know they will go at least 50K plus....
True. I wish they offered them in black, not everyone wants red. I may have to powder coat them black
T
tyet
There is no effect on warranty if you go with the Carbyte option.
Thanks, I'll see if theirs supports the 2025 model yet. Also, doesn't disabling the afm/dfm put more stress on the transmission as the transmission thinks it's at higher load. I read about people experiencing rough shifting over time.
DontTaseMeBro
DannyMal77
Started blacking it out, next up will be replacing all the chrome window trim and roof rails with the black oem parts from the RST.
Looks awesome! Have you replaced the window trim and roof rails yet? Any advice removing them? If I understand correctly, you have to drop the whole roof liner to get to the mounting hardware. And on the window trim, the lower pieces look to be held in with a few screws, but the vertical trim piece has plastic retainers that look like will have to break to remove?
I plan to do the same mods when I get my High Country in a few months.
Stbentoak
When I get my Denali ultimate in May or June I plan on removing all the chrome window trim and replacing it with black from the AT 4.. I will probably just put black film on the roof rails, not worth tearing them apart. I really would like to see an ultimate up close to see what to see what trim I could live with and what I can't. Don't really want any chrome..
T
tyet
I purchased all the oem parts, awaiting scheduling at my body shop for the install.
T
tyet
Black RST roof rails, window trims, and door handles installed. Replacing the roof rails did require dropping
the headliner. Next up is replacing the front grill and chrome bumper fascia trims to all black (again from the RST).
T
tyet
In case this is helpful to anyone, here are the part numbers for the oem black parts. This will black out every single chrome thing on the vehicle. Depending on where you get parts from, you are looking at around $2000 in parts (the grill is the most expensive at $511)
84496227 bezel
84496193 (S)COVER
13526766 (S)HANDLE
85590194 MOLDING
85590195 MOLDING
84844389 MOLDING
84844390 MOLDING
85649797 RAIL
85649798 RAIL
85136434 MOLDING
85136435 MOLDING
84977518 F FASCIA
86545889 R FASCIA
85775020 Grill
hellz
