Where Is The Fuel Control Module?
Vinmega
Hi All,
2 things;
I have a 2024 GMC Yukon XL Denali
1) Where is the fuel control module located?
2) What scan tool can I buy to program/diagnose/etc this truck? (for example my Benz I have a laptop with Xentry on it and Vediamo which lets me flush the torque converter, or make 5 blinks on the turn signal, lower the air suspension, etc), is there a tool that I can buy that allows me deep level access?
blanchard7684
Senior Member
On the SUVs, the fuel pump driver module is on driver side near the rear of second door. It is mounted to frame.
If you want a bidirectional tool they are north of $300 for good ones. For deep level access and some very basic programming overrides, etc...this is what you need. Autel is a popular brand. They have basic bi-directionals starting at $300. You can get some up to $3500. There are other brands in this space: gearwrench, innova, thinkdiag, etc...
However if you want to get detailed diagnostics with data logging then OBD fusion app combined with Veepeek OBD BCheck BLE is a plug in module that works with the OBD Fusion app very well.
I have an OBD + Link plug in that works ok as well.
The plug in bluetooth scanners run between $30-$50 and have lots of features beyond trouble code scanning.
jfoj
These newer vehicle are not as easily programmed as older vehicles. Over the past 5 years things have become far more complicated and hard to hack/crack.
You probably would find a tool from some 3rd party, but you need to be VERY careful. I know there are some tools that will actually corrupt the OE software and cause all sorts of problems.
As mentioned, there are a lot of decent phone/tablet Apps for generic OBDII that support our trucks and anything since 1996. But you are probably going to needs to spend $400-$1200 if you really want more access to other modules and features and even at this price point you are not coding/programming.
I am well aware of all the European vehicle configuration option probably up to 2020 and there were a lot of hacked and 3rd party tools, but I would not expect to find this same level of features for any of the 2020 and newer US vehicles.
V
Vinmega
Thank you, this is a great forum. Great members and very helpful.
Silentnight008
