While I’m at it…
Snackz
Having my 2011 Yukon XL transmission replaced.. I know my manifold bolts on the engine need to be done, anything else that would be preventative or smart to investigate while we in there?
rdezs
Since the starter is out, great time to replace the crankshaft position sensor with an ACDelco or genuine GM one. Located behind and above the starter. And if that's the original starter, I'd also replace it with an AC Delco unit. New, not rebuilt.
When doing the rear main seal, you will note that GM puts the seal flush to the outside of the seal bore in the cover. It's pretty common to go ahead and drive the seal in further against the recessed flange. Maybe 1/8 of an inch deeper at most. That ensures your seal will be running in a different spot on the crankshaft that doesn't have any wear. I'd recommend the felpro rear main seal. And note that it goes on dry.
petethepug
Michael
SoCal
Replace the exhaust manifold bolts with ARP units. Say goodbye to broken studs forever.
Definitely get the oil pump o ring when the pan is off. The mechanic will love you for doing the pan when the trans is out. It’s easier to access and line up.
If you’re feeling like a you deserve an early XMAS present, install a set of bigger sway bars. They suck up all the slop the truck got you used to over the years. It’s a huge difference in your ride enjoyment.
bd928
