Hiro's 2010 Yukon Build (Betty White)
Sir_Hiro
Sir_Hiro
Junkyard run was a success.
Got a upper denali grille for 30 bucks. Lower was destroyed.
A new rear window switch to replace broken. All in all a good day.
Headlights are next on the list to buy. Found the mounting tab on the passenger side is busted plus they are way to sunbaked to recover.
Yhe headlights don't look too far gone. You can always epoxy or plastic weld a broken tab.
Sir_Hiro
Sir_Hiro
Pictures make it look better than they really are. A pair are only 80 bucks so imo thats worth it than fiddling with jb weld and sand and clearing
Sir_Hiro
Sir_Hiro
Perks of having a Brother in HVAC. Recharged the AC in the Yukon. It had 0 freon..so it has a leak somewhere but it works when charged.
Also got around to steam cleaning the whole inside and holy moly was it dirty..got 90% of the stains out so I call it a good day.
Sir_Hiro
Sir_Hiro
Got around to test fitting my Camper to the Yukon. (Whole Reason I bought it) to measure to see what lift I wanted to do up front (1 Inch). Also had to order an 11" Drop hitch as well just cuz of how low this camper sits at level.
Camper is called "Patchwork" for obvious reasons lol.
I had a 2002 Cheyenne popup that was similar to yours, but sold it about 12 years ago. Those ABS roofs can sure get in bad shape. I re-covered the roof with fiberglass mesh and an ABS slurry of MEK and ABS pellets. But after that I applied Grizzly Grip over all that.
I have a couple of Bargman LED marker lights for that camper if you're interested. One amber, one red, new in packages.
Sir_Hiro
Sir_Hiro
Yeah..my roof is delaminating pretty bad but the PO in a rubber type paint. But I'm not willing to bite that bullet till the C10 is done. Got a couple other projects ahead of the campers roof. For now it doesnt leak canvas is in ok shape and the interior is pretty mint. I'll prob upgrade my camper here in the next couple years so I might just let the roof be the next owners project. Who knows.
maxima
