It Rained so 2015 Yukon won’t start, Help!
MD-Wood
I'd start with a good cleaning of all of your ground points in and near the engine bay and BCM. After that, I would suspect the BCM or at least its connections. The WD40 on the BCM main connector is a good idea to try. Given that the behavior is different when using the key fob, I would trace the wiring from the start button to the fuse block and BCM as well.
Re crimp your battery cable ends. Hot/ cold dry and humid all have effects on these ends and that year had connector issues.
Hitman
As always whenever we get wet weather our 2015 Yukon won’t start. The dash goes funky, all the warning lights, multiple service issues on screen like
-service airbag
-service trailer brake
-service steering column lock
-service front camera (doesn’t even have one)
Sometimes dash will go black like dead battery, won’t roll over at all then dash will go funky. Weirdest of all it will start off factory remote start on fob. I managed to get the scan tool on it and this is everything it gave me
Service steering column lock
Service airbag
Service front camera
C0110-61 pump motor circuit - stuck
Erased and all went away
U0140-00 lost comm with bcm
U0155-00 lost comm with IPC
U0170-00 lost comm with pass presence module
B2575-04 headlamps control circuit open
B2645-07 ambient light sensor high voltage
B2699-04 right headlamp circuit open
B305A-00 no response from steering column lock received
B3111-00 keyless entry transmitter 3 battery
B3935-00 transponder authentication
B3979-00 no environment identified received from hvac module
C0755-29 right front pressure sensor to few pulses
C0750-29 left front tire pressure sensor to few pulses
C0760-29 left rear
C0765-29 right rear
U0078-00 control module communication low speed CAN bus off
U0164-00 lost comm with HVAC module
U0208-00 lost comm with seat memory
U0236-00 lost comm with steering control module
Erased and all gone but
B305A-00 & B3111-00
U0029-00 MOST bus performance
Erased and went away
U0078-00
U0151-00 lost comm with inflatable restraint sensing and diagnostic module
U0155-00
U0184-00 lost comm with radio
U0198-00 lost comm with telematic control module
U0230-00 lost comm with liftgate control module
Erased all went away except
U0184-00 & U0230-00 stayed
This has been a major pain in the hole, I’ve seen many other write ups with similar problems but I’m yet to come across a fix, has anyone managed to find a fix to this extremely frustrating problem. Any help would be appreciated, doing everything I can to avoid a trip to hells gate (local dealership).
Thanks
In my 2015 yukon XL I had a similar issue water was some how getting into the truck, the passenger floorboards always wet. I tried everything to find the leak, cleaned sunroof drains, etc, looked at AC coil nothing, taped up some holes in the fender by hinges, sealed around the battery area, so on.
In all of this I pulled off the passenger door sill and trim then lifted the carpet, in the floor rail there is a wiring harness and connector. It was full of water.
I never had anything short out but always on my mind when it would happen.
Maybe this might help your situation.
Y
Yukon2703
I managed to get the truck into the garage the other night, it started but most of the dash wouldn’t light up. I pulled it inside and decided to unhook the battery cables and let it sit to dry for a day or two before going back to it. When I walked behind it I noticed the out led ring of the drivers tail light wasn’t working, I bumped it and as you can see in the video it just kept flickering. I left it to sit for a couple days then it started right up and worked as it should, I drove it all day yesterday and it worked fine and I parked it in garage last night. Raining this morning, drove it for 10 minutes then parked it back inside, went out a few hours later and back to the no start issue, dash lights up but nothing when hitting the start button. My next plan is to remove tail light to see if water is getting in there.
Y
Yukon2703
Latest update, still no luck with the Yukon, I ordered a new tail light that will get put in this weekend. I’m wondering if there is anyone that can give me an idea of where modules are located on the truck that could get any water on them from driving or just sitting out in the rain. I’m just going to go module by module making sure they’re good and clean, spray all connectors with contact cleaner and give everything a healthy does of dielectric grease before I put it back together. Hopefully this will help me find something. Thanks in advance for the help.
Isaac2468
Just wondering if you had any luck with it by now? I have the same exact issue for over a year now and can’t find it!
Acruz
Hi
Any updates im
having same issues wondering if u solve the problem
Thanks in advance
nduck
