Horn is not working
Samuraj
Des plaines
Fuse # 93 is OK , no power to the fuse , and few wires cut by horns
What can be done ❓
justchecking
SW Ohio
Try to fix it yourself. Still burns me that I paid $350 for Ford to replace my daughters horn I could have gotten at advance auto because “it was to cold out ” for me.
Samuraj
Samuraj
Des plaines
o yea , I'm good with tools , diesel mechanic from young age ;) ,slowly i get to the bottom of this .
What can be done ❓
Boarder patrol truck here. I was told they activated sirens with the steering wheel horn switch. I direct tested my speakers and got nothing. I added a new horn, fuse, relay, and put a horn swich on the ledge directly below the ignition. Looks good, sounds good. My horn problem solved.
Samuraj
Samuraj
Des plaines
This is what I have , no brown wire in sight, not around gas pedal too
Just the reminder ; my hoe have no spot light , all lights and door locks windows works
What I’m missing here ❓
You're missing some context in the pics. Why not untie that bundle and see if there are numbers on the harness, and also show where it comes from.
Samuraj
Samuraj
Des plaines
Maybe this help …..
cpranger22
