Metallic Rattle While Accelerating - Dealer Can't Reproduce (video)
djnice
I do hear it. That would bug me and I would be worried about an engine issue. It does sound like pre-detonation.
In my experinece I go to different dealer and tell them what the other dealership did. Then they are happy to win my business.
viven44
Dallas, TX
Actually, sounds like valvetrain clatter... (Excess lash from lifter not pumped up)
0x_2a
It's a stuck lifter. Reproduce it in park, and rev around 1700RPM and 2200RPM. WHACK WHACK WHACK WHACK WHACK. That poor camshaft is getting beat to hell with a stuck lifter.
Good luck getting authorization for a fix. I've been fighting to get it fixed for months now. I found a dealership where it bothered the techs also, but they couldn't get it authorized for warranty repair. To fix a stuck lifter, you have to disassemble the entire engine, all the way down to the head, inspect the camshaft (which is for sure getting damaged). I had a motor fail from that issue at 18K, and am now on my second motor, which is again failing from the same issue. DM me if you'd like to share notes.
Here's what it will sound like when it gets worse.
LazyWave
