Brought a new (to me) Burb home
Loki223
Loki223
Elk, WA
But i did get the passenger seat done this weekend
Old seat cushion, had the same red stain.
Looks better blue
Alos, the seat shop recoemnds starting in the front when pressing the hog rings in, and then moving back from there. I did the oppisite on the driver's seat, and this time i listened to them. They are right, start in the front, and then move back from there, it was much easier
This side of the project ook an hour start to finish. Thats popping the trim panels off the front of the seat rails to popping them back on. Really not that bad of a job
Loki223
Loki223
Elk, WA
But the more importanter project for the weekend was another success story.
Esky tail lights,
They are both Morimoto XB series tail lgiths
With the backup light booster
I will say, if i ever need to pull the trim panels off on the rear hatch again i may consider buying new replacements. I can tell they've been off before and they don't have to many cycles of being removed left in them. But i also don't see a need to to remove them again in the near future. New seats are supremely comfortable. Very happy with the projects this weekend. Also a shout out to the guys over at Dudes Diesel Performance (DDP) and Glacier Diesel Performance (GDP) I realize i got hooked by them due to my other hobby of diesel trucks, but they helped source several of the parts and pieces and can get just about anything i need for the burb too, so i heavily rely on them. Good people, small town Texas family owned business, and i do like to support small family businesses when possible
Although admittedly, when i started buying from GDP they were based less then an hour from my house, but as things change the great customer support remains the same
Loki223
Loki223
Elk, WA
Also, pretty sure i'm going to buy the Morimoto headlights for the burb at some point in the next couple of months....I have been pleasantly surprised by the stock HIDs, however the driver's side DRL LED is failing, and if i'm going to take it off to fix the circuit board and reseal it....why would i put a factory part back on when there are aftermarket upgrades out there? Which means if i'm pulling the bumper i might as well add on front tow hooks and swap out the tow hook plastics to accept them...and might as well upgrade the fog lights with some LEDs as well. that's the part that has me torn, i love the quality of Diode Dynamics, however i prefer the look of the Morimoto fogs and that crisp LED fog line is just something to be in love with, so i think i'll probably end up getting the XB fog lights as well. But that's a problem for me in a couple of months when i get around to doing that
SpareParts
North Idaho
On the 07 to 14 you can take the inner finder loose and get that nut loose holding the headlight in. Maybe yours the same?
Jmartin1635
