ivin74
05 NBS Nali
As some of you know the front bumper to the NBS Yukons have a large gap. Since I bought the truck that has always bothered me so I decided to fix it. several weeks ago I tackle the fix and finally, I'm able to do a write-up. The tools needed for this job are screw drivers and a 4" grinder with a cut wheel.
First, remove the front bumper by following the link below.
Once the bumper is off, cut off the clips on each side of the frame. as shown on the picture below
Once they have been cut, clean and prep the areas as shown below, this needs to be done so you can weld them back. Your local muffler shop can welding them back for $ 30 plus or minus, more about this later.
Now buy 10 washers from your local hardware store. Make sure the OEM bolts slide in the washer. Put 5 washers together on each side like the picture below. Now re-install the bumper and bolt it down. At this point, you can only install the top bolt on each frame rail. make sure the bottom of the bumper is flush with the frame.
https://www.lowes.com/pd/Hillman-5-Count-10-mm-Zinc-Plated-Metric-Flat-Washer/3012831
