01 suburban w/djm 3/5.5
carcrz
Georgia
who are you referring to tony?, i dont have an issue i just dont want the alignment shop to raised my truck back up when they do the alignment
PUNKYOU007
PUNKYOU007
Hopewell VA
I will assume its because I did not put the keys back in right. How will I know? Is there a certain way they go back in? It should be as easy as taking the bars back out and just re indexing the keys right?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
any shop that knows what they are doing at the 3 inch level the djm a arms will align perfectly fine. if your at 32.5 it will align fine ive done it many times and may others have here also.
carcrz
Georgia
punkyyou007 did you adjust your tie rod ends before going to the alignment shop to get your wheels pointing straight?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
for tie rods easy
measure front of front tire from center to center lets say 50 inches
measure rear of front tire from center to center lest say 51 inches
move both tie rods out 1/2 inch per side that will get you at least going to the shop.
PUNKYOU007
PUNKYOU007
Hopewell VA
Is there a way for me to figure out where my keys should be?
I will assume that since my bolts are almost all the way out and I am still to high that I need to turn the keys them self up one.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
With the bolts all the way out you should be at 32 to 32.25 about.
yes keys will need to be turned
PUNKYOU007
PUNKYOU007
Hopewell VA
Tony, i just tried calling u. I am trying to get this key in but am still having an issue. Please call me back 8044796050
Sent from my EVO using Tapatalk.....*****.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
able to hear voice mail but out of battery juice right now.
you said your one key the bolt is fully backed out thats fine now on other side you said the shop fully put the bolt back in. Unloosen that bolt all the way out like you have on the other side.
WIth both bolts backed out it should sit lower. If one side is fully bolted up it will in turn also lift the other side up.
Champ74
