01 Tahoe Bolt on Mods
Camaro Chaos
Hey everyone, I just decided to take my 01Tahoe and make it more responsive. I want to do all bolt on first, well I'll slap a cam and headers too. What would u recommend for a cam? I want to most radical sounding w/o using a stall, maybe just some tuning. Should I get a programmer or will I need to have the prom flashed to match the cam? I need info on what lbs injectors I can jump up to, will this LS6 intake b worth the swap? Will I need to do anything other than a shift kit to the trans, like change the servo out of a vett? I'd like to keep it a naturally aspirated engine! Money is a issue so keep n mind I'm doing a budget build. Thanks everyone!
Z-56 Hoe
What do I do????
Houston
are you going for top end or raw power? oh yeah mine is a 2001 and is NA some things I would sugest: cam, 4.8L heads ported and polished, intake, LT headers I am a big fan of the dynatech LTs with the free flow cats, gears go lower, Billet B&M servos, shift kit, Tune,
brucebruce45
to be honest you have alot of researching to do if you are already asking all these questions
puckhead
CO
Welcome aboard first of all!! I cant answer too much for ya, but there is a lot of great info and very helpful people on this site. If you havent tooled around in the 01-06 section take a look there, might answer a lot of your questions. As for the tune, check out Blackbear. They are a vendor on here and are great people! Hope you get the ball rolling on things!
KrautBurner
Bremerton, Wa
sounds like you need to find a tuner / engine builder and just tell him your budget.
and let him make all your decisions for you.
where are you located?
andrew383
indiana
4.8/5.3 have the same heads bro..
862-99 and up 4.8-5.3 Truck heads
706-99 and up 4.8-5.3 Truck heads
799-05 and up 4.8-5.3Truck heads ***reportedly came on a few corvette's too*** These are basically 243 Heads
+1
tony97218
