huffster329
I would first verify that the fog light relay is in the fusebox. If it isnt then acquire the correct relay. Put a meter on the normally open contact terminals in fusebox to see if one side is hot (12v). Test inside oem fog light switch to see if relay energizes relay and closes the contacts. If not then that will need to be corrected. COuld possibly be a PCM program issue. Ill have to check my schematics to verify that one.
This is the fuse box the way it was.
I added the relay. According to the diagram on the back of the fuse box cover, the 15 amp fuse to the left of the relay is for the fogs too (it was already in there.)
Installed the new switch.
I am getting power to the fuse and the lower left terminal where the relay goes.
