01 Yukon, Rough Idle, No CEL, Clean MAF
TurtleBeach
All my searches for rough idles w/o CEL turn up "clean ur MAF sensor". Well I did that and it didn't help. I know it's not a fuel issue b/c I just put a brand new AC Delco fuel pump on it < 2 months ago (and the rough idle was there b4 the fuel pump went out).
What's next, plugs and wires? and if so, do I need to get some high end wires (like Taylors) or will the standard Oreilly' replacements do?
The rough idle isn't bad, it's pretty mild but it's just irritating, lol.
T
TurtleBeach
Ac deco wires should be okay... Check your sensors as well...
Which ones, like O2 sensors ? I was under the impression from reading that if any of the sensors were bad that it would throw a check engine light?
afpj
O2 sensors may not throw any code when they are failing. They will code after they have failed. May not even be a sensor code that shows up as its failing. Got a catylitic inefficiency code once, but after looking at the voltages on realtime monitor, found a post cat sensor was going bad.
T
TurtleBeach
Ahh, ok, thanks for the heads up, I may just replace them to be safe then after I do the plugs and wires.
Ne44035
