Not sure what happened but I couldn’t get on the forum. Kept getting a 1020 error code saying access denied. Thought maybe I was kicked out but all I did was shut my phone off for a couple hours while I was working and turned it back on. Just letting it reset is all it took.
I woke up about 8pm and didn’t have it in me to go out in garage for a couple hours before work. Ended up passing back out until 9:20. Felt good not having to come to work early and getting some much needed sleep.
My parts showed up so I threw them in the truck and off to work I went.
The forward lateral link bars are non adjustable from factory but the Mevotech replacements are adjustable and use the same link for both. The trailing arm is not adjustable and I had to go with a Delphi unit because the Mevotech ones weren’t in stock. They had some economy ones but they weren't round bar, they were C-channel and I didn’t like that. So this is what I have.
First thing I did was anti-seize the threads and then threaded the ends in all the way making sure the ends were facing the same direction.
Then to adjust them the same length as what came off I used a 9/16” bolt on one end and had to use a 15/32” drill for the other end. One side is 14mm and the other is 12mm so a 1/2” bolt was too big and a 7/16” bolt too small. I didn’t bring the bolts with me but this worked fine.
After I adjusted it to same length I marked the new link with where it belongs. I only had to mark the rear links because those are the only ones that were adjustable which sets the rear alignment. The good thing with having the forward bars adjustable is it allows a finer tuning on alignment. I guess when you only have the rear link to adjust toe its give and take because it will effect camber. With both links being able to adjust you can get it in spec as opposed to 1-2° acceptable limit. Just what I’ve read while looking into it.
Wiring the stereo adapter and tweeter now before I go home and put this thing back together. Fill you later.
