03 Denali which Optima Battery?
erock198
erock198
Schenectady, NY
I dropped my truck off to my mechanic friend to fix the ac compressor and the fuel pump and to find the draw and to put in the battery buddy. I work on computers not cars anymore ;)
If I need to replace the battery it will be an optima. I thought I found the draw but I guess not since it was dead after 24 hours
clandr1
Dallas/Fort Worth, Texas
I've been seeing a lot of accounts that indicate Optima's quality control/build quality has taken a nosedive since they moved production to Mexico a few years ago.
The Die Hard Platinum, which is an Odessy battery sold by Sears, is the current "reigning champion" of batteries.
kebm
I have a yellow top optima agm in my Yukon right now. I had a dual battery system in a jeep with 2 yellow tops. They are a great battery. The one that is in the Yukon was used in our camper for several years, then sat in the basement unused for a few more years until a month or so ago when I finally put it in the Yukon. I would charge it whenever I would think to, usually about every 3 to 6 months, and it was amazing how it held the charge that long. It would never be below 12v.
If you have a Sams club in your area, they have Duracell agm batteries at a better price than the optima, and in my experience perform just as well. I had one in the Yukon until I moved it to the pacifica recently, one in the T&C, and two deep cycle Duracell agm in our camper. No more corroded cables or trays because they vent barely any hydrogen gas compared to a wet cell battery, they hold a charge much longer, and they last longer. The two in the camper I have mounted sideways. The Yukon is not a daily driver, it is just for towing a camper, so it sometimes sits for several weeks. Also it is not driven in winter. I just put a charger on it every 6 to 8 weeks or so to top it off. I have never found it flat as I had with the previous wet cell.
So, I say go for it after you fix the draw issue. Also, it sounds like you need a high output alternator to keep the battery charged up. Drawing a battery down past 50% charge will shorten its life significantly. I would look for an alternator that can supply at least 105 amps at idle, and your battery should last much longer.
erock198
erock198
Schenectady, NY
I recommend a battery buddy to anyone. I hope I found the draw being the adapter for my lappy still plugged in inside the console. Doh!
I did leave the key on for an hour with the radio off and it tripped the buddy but that was the interior lights not turning off. I have still to see.
erock198
erock198
Schenectady, NY
loho16
NOVA
I agree with YukonXL sounds like something that was installed is constantly running/drawing power and it is killing your batteries. I believe all yellow tops are deep cycle.
erock198
erock198
Schenectady, NY
It was the inverter but everything is good now. The power switch was off on the inverter but it was still drawing.
Saltyfinfan
