I am new to the forum. I have a 03 GMC Yukon 5.3 liter flex fuel with autotrak 4wd-L460E transmission.
It has 233,500 miles. Purchased in June of 2015.
Up till November 2018 it has been good with no major issues other than routine
maintenance and repairs.
It has developed a shudder between 40 and 50 mph. More noticeable when going uphill at that range and transmission is right at the spot it switches into overdrive.
Maintenance performed,
1. New filter and fluid (Ac Delco dexron 6)
2. New shift solenoids
3. Torque converter solenoid
Did not replace the pressure control solenoid.
4. Drained/filled rear diff (G80) with 80w/
90 gear oil with new gasket and added AC Delco friction modifier. After rear diff fluid change seems the shudder is worse. I know it is suppose to have the 80w/90 oil but thought 75w/90 synthetic might be better???
5. New spark plug wires and plugs.
Does not appear to be a misfire.
Based on what I read sounds like torque converter???
Local transmission shop with great reputation quoted $1,000 for torque converter and replace rear oil seal.
$2,000 for getting transmission rebuilt.
Anyone else have similar issues and/or what the cause and fix was??
I appreciate any advice.
Thnaks!
Thnaks!
