04 Denali Headlight Inspection and cleaning
All true including the part mentioning the guys on gmfs being idiots :rotflmao:.
Also the fact that the brackets line the projector up exactly horizontally, where normally without the brackets you have to put the headlight on the truck then align the light rotation output and hope when you take it off to secure that position it doesn’t mess up the alignment.
Oh yeah forgot about that fun part.
Geoffsfas10
St. Louis
I did the adpaters and mh1's in my old denali headlights, takes maybe 20 minutes if the glue holding the oem ones is tight. i held on to my OEM halogen projectors for so long but no one ever needed a set and i tossed em a few weeks ago. oh well, the HID retro is the way to go
S
Sdp1234
Southeastern PA
4BC7A239-008E-4E1B-A1B1-415C4790C8E6.jpeg 2107EE0D-CAE4-431B-BF8C-D8F6FDF18284.jpeg CFCA1F8A-5AC4-4234-AD22-3B1285E6EF6D.jpeg A794D3B6-281D-4776-85ED-08A6299A7F11.jpeg Well today I started the project. Figured I’d first try to install the TRS acme lights in my 04 Denali. Got things apart and got to the point of installing the acme hids. Seems that my cb&d brackets may have an issue with the acme lights. The lights will not lay flat on the brackets due to the screws that’s hold the lenses in place
Any suggestions? I was under the impression that the acme had the same footprint as the mh1s? 5EB97509-1AE9-458F-9DCD-B0E723F2DFAF.jpeg
I don't think those are going to work. I know the brackets I bought are advertised as being designed for the Moromoto's. They look slightly different than those but regardless, it doesn't look like those are going to work for the Acme's. Here's the brackets I bought, and the mini H1's. You can see the difference in the projectors between mine and yours and in the first pic you can see they're cut out specifically for the Moromoto's.IMG_9402.JPG IMG_9428.JPG
S
Sdp1234
Southeastern PA
I don't think those are going to work. I know the brackets I bought are advertised as being designed for the Moromoto's. They look slightly different than those but regardless, it doesn't look like those are going to work for the Acme's. Here's the brackets I bought, and the mini H1's. You can see the difference in the projectors between mine and yours and in the first pic you can see they're cut out specifically for the Moromoto's.View attachment 261552 View attachment 261553
I’m going to make them work. Mounting holes are perfect so I’m going to dremmel the mounts until things fit flat then just a bit of silicone should fix the small hole that will be remaining.
What sealant did you use?
S
Sdp1234
Southeastern PA
I’m slowly working on this (a bunch of other things in life keep interrupting the process) Where have folks mounted the relays for the HID’s? Almost have the lights done and I’m looking to finish the wiring.
I put mine on the radiator core support, used 3M high bond tape.
05Single
afraid of the dark
Put mine on the engine side of the radiator core support on the passenger side next to the air filter box.
yukonfan
The Morimoto Mini H1’s have amazing output, you’ll be super happy. The adapter plates make it a super easy job, normally you have to bake open a headlight assembly in order to do a true retrofit like this. This way everything just screws in from the back. And you can buy the pigtails already assembled from TRS so you don’t need to do any soldering. I did this exact same thing to some new Anzo U-Bar projectors for my 02 Denali, came out super nice. I did a write-up over at GMFS.com that got very little attention which I don’t understand but then those guys are all pretty much di*ks.
https://www.gmfullsize.com/threads/retrofits-in-the-new-anzo-u-bar-headlights.319939/
is there a kit i can buy that comes with everything? I have the denali headlights but my low beams suck even with new bulbs. The high beams are great but my low beams blow
Jayster0966
