05+ Cooling Fans Direct Fit
O
orange57
Do you happen to have the wiring diagram for putting in a condensor fan? I'm assuming I will need one relay to run the power through for the factory fan. Where do I tap in for the clutch activation.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Fuse the power side of it to a 30 amp aux fuse on the power block under hood if available or the battery and use the dark orange wire of the clutch to one terminal of the relay coil and ground to the other. When the compressor clutch activates the fan will turn on.
Djohnson99
