Num12005
- Joined
- Sep 19, 2016
- Posts
- 186
- Reaction score
- 74
It doesn't whine while off the accelerator ,only with power applied,even barely.I haven't abused it at all except for overloaded towing,I don't think your suppose to haul a tahoe with the same tahoe,but idk..I ha e a yukon duragrip posi I bought for my c10,I think it'll work in this 8.6..I called lkq and they want 900$ for a "low.mile" replacement,which is 130k..
Did it whine during deceleration or acceleration? I ask because if it only whined during decel it was a loose pinion nut that needed to be retorqued, if it whined during both could have been that the nut was more than just loose. I can't imagine a bearing being bad and lasting over 40k being that loose to have pinion end play that bad. I'm not sure about the whole difference between JL4 and non JL4 RPO. Maybe someone can educate us about the differences, could be just different brake pads or brake pistons. As far as going with the 1 wheel wonder, I would rather have the option and not use it than not having it and having to use it. Although knowing the g80 it might put you in this very same situation again if abused, so its really something to think about. Salvage yards are a good place to get them for cheap.
