05 yukon front hub assembly
rockola1971
Indiana (formerly IL)
18 and 15mm wrenches (Brake caliper and hub mounting bolts) and 36mm for the axle nut. Get the axle nut loose before you even raise the front wheel off the ground. Dont be surprised if you have to beat the old hub out. They often seize.
Overtightening is just as bad as undertightening axle nut. They both result in premature hub failure.
